Throwout Bearing for LS7 Setup
Old Mar 10, 2006 | 09:58 PM
Rescue Ranger's Avatar
Default Throwout Bearing for LS7 Setup
Hey everyone
I'm kinda new to the clutch arena, and am looking at a LS7 setup. This might be common knowledge to some people but..
When ordering from GMParts Direct the
LS7 Clutch/PP
LS2 Flywheel
What about the throwoutbearing, etc.? Is there anything else needed to install this on a 02 ls1?
Search didn't reveal much about the throwout.
Thanks.
Old Mar 11, 2006 | 04:49 PM
Bump. anyone? Does the throwout bearing come in the package with the Clutch/PP ?
Old Mar 11, 2006 | 05:01 PM
MattIROC's Avatar
I didnt get a throwout bearing with mine, I got the clutch/pp and flywheel, not the entire kit from a sponsor.
Old Mar 11, 2006 | 05:07 PM
where do you get the TO? did you get it from dealer, etc.? which one is it, for LS7 or LS2?
Thanks.. sorry for the 1billion questions.
Old Mar 11, 2006 | 05:58 PM
P Mack's Avatar
I used a stock throwout/slave with my ls7 clutch, but i've been wondering if the ls7 slave is different.
Old Mar 11, 2006 | 09:05 PM
blueovalbeater's Avatar
Lightbulb
Finally someone with same question as I have. It sounds like the LS7 hydraulics are different including master and slave cylinder. I saw one post where corvette guys were using LS7 clutch and flywheel with C5 hydraulics, meaning that the same may be able to be translated to Camaro/Firebird in the the hydraulics and thus the slave need to be LS1/LS6 type. Keep in mind that the LS7 and LS2 flywheel are identical and same gm part number. I called scoggins and you can get the complete kit with throwout for about $399 and clutch and flywheel wout throwout for about $340.
We need more info to verify if my theory is correct, that the LS7 slave/throwout will not work on an LS1 meaning I will go the route of purchasing the LS7 clutch and flywheel and not the clutch package.
Old Mar 11, 2006 | 10:03 PM
Yea i'm really left in the dark as to the parts needed to get this install right. It seems LS1Joe is selling a full kit for install on f-body.. but I'm not sure what is in that kit
Old Mar 11, 2006 | 11:47 PM
speed_demon24's Avatar
My dad put an LS7 clutch in his 00 WS6 and just used the upgrade f-body hydrolics with no problems...
Old Mar 12, 2006 | 08:54 AM
HavATampa's Avatar
From every thread I've read and based on the parts I ordered, the stock T/O bearing works without upgrading. Not sure if the LS7 T/O is better or the same, but the upgraded LS1 slave and T/O works. I haven't installed mine yet, but basing this info on the many threads on this board of people that have installed it. Here's a list of what I purchased from Fred's. I already have the upgraded master and no the slave and T/O bearing doesn't come with the clutch kit, it has to be purchased seperately. The clutch kit only consist of the pressure plate and clutch disc, no flywheel or slave or T/O:
ls7 clutch kit---------24233650 $300.67 (New # is 24236500 $287.09)
ls2 vette flywheel----12571611 $178.00
slave clyinder and T/O bearing --------15046288 $107.45
ls1 pilot bearing------14061685 $9.53
total ------ $595.85
Old Mar 12, 2006 | 11:39 AM
Thanks so much man. This was the post I was hoping for.
Old Mar 12, 2006 | 12:39 PM
MattIROC's Avatar
yeah I used my stock throwout bearing also, works fine. My master and slave were upgraded with the last clutch I had.
Old Mar 18, 2006 | 10:46 PM
billazls1's Avatar
Wink
EDIT: Non-Sponsor link removed by Admin
Old Mar 19, 2006 | 01:31 PM
yea but they aren't a sponsor, and I bought everything I needed for my 02 (didn't buy a slave) for $526 shipped from SDPC Sgoggins --> The told me it'll be in tomorrow.
