Short shifters?
From my observation, even though shorter sticks shortens the length so you will yield yet a shorter shift at the handle itslef, it's shorter length may be trickier to reach than the included ones with the Hursts, Pro 5.0, and/or B&M. I discovered that having the stick handle closer to a "4 o'clock" position with a slightly longer gear to gear shift length, was actually quicker and yielded a more positive overall feel for the shift positions than having a shorter stick that had much shorter gear shifts to engage, but a much longer reach from steering wheel to shifter and the shorter length between the shift engagement positions actually made it trickier to determine the appropriate gear shift positions, since there was practically very little "slack" between them. I didn't realise this until I switched back and forth between shafts several times while AX and RRing.
Just my 2 cents
I can best describe the OE shifter like a broomstick in a bucket of oatmeal.
