Clutch won't bleed!! HELP??
You need to tighten the bleeder screw BEFORE you release the pedal, otherwise you are just drawing air right back into the system.
1. Depress pedal
2. Crack bleeder
3. Close bleeder
4. Release pedal
5. Pump pedal back up
6. Repeat above many many times.
I did it that way because it makes one-man bleeding very easy.
Get under the car with a punch. Make a few dents in the tunnel right across from the bleeder screw. Get inside the car, pull back the carpet, and drill a hole an inch or so wide where the dents are. Now you can access the bleeder with a socket and a few extensions. The best way to do it now I found is to lay across the floorboard, with one hand working the socket to open/close the bleeder and the other hand pumping up the clutch pedal.
Also if you have a mityVac you can reverse bleed the car without having to put it on a lift. You don't even need a buddies help with the MityVac. See the third part in my sig link.
Mike
If you have a power bleeder, attach it to the resevoir, pump up to 15 psi pressure, crack bleeder, wait for solid stream of fluid to come out, close bleeder, all done!
Dan
There is absolutly no way in hell you could do that in 5 min
Maybe you should use the confused face icon instead or do some research. I can actually do it well under 5 min if the car were already jacked up in the air BTW
. 1.) filled clutch fluid resivoir and put lid back on!!
2.)had a friend pump it up a few times and let off
3.)cracked bleeder had him steadily push pedal to floor and hold it
4.) tighten bleeder
pump up again let off
same thing over and over seriously like musta did it 5 times or so
had car up in air on jackstands, and put ebrake on, and started car and checked to see how clutch was working. pedal should feel pretty firm too!!
hope this helps, and please BE PATIENT and dont get upset!!!!!!!
yeah!! its definatelly a PITA! i used a small craftsman 1/4 inch drive ratchet and a 12mm deep socket.
i believe i put the socket on the bleeeder first, then put ratchet on! super tight area up there!!
