spec 3, what flywheel???
Old Mar 13, 2006 | 06:25 PM
mcamarols1's Avatar
Default spec 3, what flywheel???
i bought a spec 3 clutch, and just been sitting in my room for a while, its time to bolt it up since my stock clutch is going.
my questions are:
what flywheel should i use for a drag racing app.?(ls6,spec,fidanza,ect.)
do i need to replace anything while i got the tranny down???
any hints are appreciated, thanx
Old Mar 13, 2006 | 07:42 PM
Starz T/A 17's Avatar
Id do the spec flywheel and probally wanna replace the slave clyinder while your in their
Old Mar 14, 2006 | 12:34 PM
mcamarols1's Avatar
which one the steel or alum.????
and what about the shim???
Old Mar 14, 2006 | 01:15 PM
NLinnear's Avatar
We like to use the stock flywheel for Spec clutches. Make sure to place the provided shim behind the slave when installing.
Old Mar 14, 2006 | 01:54 PM
JakeY2KZ's Avatar
I've read that autox guys should go with the aluminum where as the dragstrip guys should go with the steel one. I'm running the stock flywheel now with my stage3 but upgrading to a billet steel when I get my spec4
Old Mar 14, 2006 | 02:12 PM
BLAKE 01 WS6's Avatar
where are you guy's getting a new stock flywheel???? i'm trying to get my spec3f put in but can't find anyone that sells a new stock flywheel. please help!!
Old Mar 14, 2006 | 02:25 PM
JakeY2KZ's Avatar
gmpartsdirect.com should have it.
Old Mar 14, 2006 | 02:46 PM
Yeah but for the price of a new flywheel you would be better off getting a spec billet steel flywheel
Old Mar 14, 2006 | 03:53 PM
TroubledWine3's Avatar
I got the 17.4lb. steel flywheel from AMS Racing(on eBay) for $150 shipped to go with my SPEC 3. It is AWESOME. I only have 200 miles on the clutch(still on factory hydraulics, too...long story, don't ask, GM slave is on it's way)...absolutely NO chatter.
Old Mar 14, 2006 | 06:40 PM
mcamarols1's Avatar
what about the zo6 flywheel, i want a good setup for drag racing.
also where exactly does the shim go and what is it for????
Old Mar 14, 2006 | 06:43 PM
mcamarols1's Avatar
where does the shim go? i never done an fbody clutch.
Old Mar 14, 2006 | 06:46 PM
mcamarols1's Avatar
"hey man just wanted to let you kno we got similar setups, have you dynoed ur car? if you have what #'s did you pull??"
Old Mar 14, 2006 | 06:47 PM
Pwebbz28's Avatar
The shim will go behind the slave/throwout bearing that is held on by 2 10mm bolts
Old Mar 14, 2006 | 06:48 PM
mcamarols1's Avatar
on the tranny side or the pressure plate side???
Old Mar 14, 2006 | 08:48 PM
333/345 on a mediocre WOT tune.
Old Mar 14, 2006 | 09:06 PM
on the slave cylinder and it bolts to the tranny
Old Mar 16, 2006 | 06:02 PM
mcamarols1's Avatar
i got 333hp and 352tq on a dynojet thats crazy
Old Mar 17, 2006 | 01:31 AM
Sounds like you got my car's brother hahaha.
Old Mar 17, 2006 | 08:09 AM
PAGregSS's Avatar
I'll put in another vote for the AMS billet flywheel. I've got about 20K miles on mine with my Spec 3 and a friend has about the same on his. We both got the flywheels for $125 shipped off of ebay.
