Need help with shifting on N20!!!!!
Old Mar 14, 2006 | 10:13 PM
n20stroker's Avatar
Default Need help with shifting on N20!!!!!
Need some help guys? When runnin N/a i have no problem going into gear, but when i spray 100 wet cannt get car to go in 3rd gear.I have new hyd and cartek clutch. Also when srayin i slip the clutch cause in runnin a 10 bolt.. Could i be heating the clutch up to much on take off? Also does anyone know what the cartek cluch is rated at cause it feels like it slips when shifting.
Old Mar 14, 2006 | 10:52 PM
AdReNoLiNjUnKiE's Avatar
Should of went with the RPS clutch!! Loves my NOS!!
Old Mar 14, 2006 | 11:44 PM
BriancWS6's Avatar
When you say you can't get it into gear do you mean that the pedal is to the floor and you can't get disengagement? In the summer heat mine did that when I sprayed as well. Once it cooled off this fall it was fine....I lost some clutch pressure by the time I was going for the 3-4 shift, but I got it in ok.
I am installing the Textralia and freshly beefed up tranny tomorrow after work. Everything should be great now!
Old Mar 15, 2006 | 07:33 AM
n20stroker's Avatar
no my cluch pedal is off the floor just wont go in gear. have to be ogg the gas then gently put it in gear.. Put it this way running 11.10 N/a put 100 shot to it and then it runs 11.00. something slipping. might change over to a th400.
Old Mar 15, 2006 | 08:24 AM
Turo's Avatar
So you mean the shifter won't go into gear? If so, I would guess that it's a hydraulics problem, not a clutch problem.
Old Mar 15, 2006 | 08:42 AM
n20stroker's Avatar
all new hydraulics installed with the clutch 4 months ago. It was part of the cartek kit.
no problem going into gear n/a doesnt like the n20
Old Mar 15, 2006 | 02:57 PM
pushinfreight's Avatar
The only other item could be the master if it is stock. They do wear out and with the 402 on spray it may just be too much for it.
Old Mar 15, 2006 | 05:03 PM
black01_WS6's Avatar
have you done the drill mod to the hydrolics? that could take care of some of it.
Old Mar 16, 2006 | 11:27 AM
n20stroker's Avatar
drill mod was done. cartek does it to all there kits.
Old Mar 17, 2006 | 09:59 AM
TransSlam's Avatar
I AM HAVING the same problem, running a 125 shot on a stock motor-new centerforce clutch, flywheel, slave and MC wont shift at high rpm. Mine has a lot of traped air in the MC. i hooked up a mity vac to the resv. pumped it up to 20psi and then pushed the clutch pedal in just to see a whole bunch of bubbles in the line. I havnt finshed trying to get all the air out yet so hopefully this will work for me
Old Mar 18, 2006 | 10:25 PM
n20stroker's Avatar
well today i take the car out and hour into it the car wont come out of 3rd gear. finally get it out wont go in first. later that night car was grinding going into 4th at high rs. Going to try to bleed clutch.
Old Mar 20, 2006 | 12:57 PM
cjels1's Avatar
you shouldnt be spraying thru gear changes anyways...
Old Mar 20, 2006 | 03:35 PM
n20stroker's Avatar
not sprayin threw gears, nos is off when off throttle. No big deal th400 goin in
