Difference between ls7 and ls2 flywheels?
Old Mar 15, 2006 | 01:09 AM
00silverz28's Avatar
Default Difference between ls7 and ls2 flywheels?
I found a really good deal on a ls7 clutch kit including the ls7 flywheel. Can somebody tell me the difference between the ls2 and ls7 flywheels? Will the ls7 work with a fbody? Thanks.
steve
Old Mar 15, 2006 | 01:18 PM
RyRy's Avatar
I was looking into the ls7 clutch as well. Where did you find the kit?
Old Mar 15, 2006 | 01:55 PM
Starz T/A 17's Avatar
I was goin to go that route and what I read was the LS7 flywheel wont bolt up to an LS1 engine correctly, you have to use the LS2 flywheel which will bolt up to an LS1 and it also will fit the LS7 clutch
Old Mar 15, 2006 | 03:57 PM
blueovalbeater's Avatar
No Difference on LS7 and LS2 flywheel - Same part number 12571611
Old Mar 15, 2006 | 08:18 PM
billazls1's Avatar
Check Sgoggins for the whole kit at about $399. They are the only ones that seemed to have a clue.
Old Mar 16, 2006 | 12:56 AM
RyRy's Avatar
can you pm me the part number of the kit you got from them? Ive been trying to price it out and with the flywheel i cant get it below 500. What came in their kit?
Old Mar 16, 2006 | 11:17 AM
Rescue Ranger's Avatar
Ordered it from Sgoggins (sponsor, SDPC --->) $526 shipped... I saw this thread and asked him the differences between the two. His response:
'Looking at the two, they are the same part number, and the exact same flywheel."
Where did the notion that the LS7 flywheel won't bolt up properly to the LS1 come from? Did someone have an issue with it?
Old Mar 16, 2006 | 12:39 PM
I have no idea but everybody has said to order the ls2 instead.
