Got my engine as a goodie bag, what clutch is this?
Yep, looks like my RAM also. It's not the VDS (no pressure plate studs), but it's a good one nonetheless. And indeed, it's not bad at all to get rebuilt. You won't know what disc until you remove the pressure plate.
definetly ram...... proly the same one as most of the guys that run ram are running...... its a 402 competition pressure plate.. the disk is the question.... look at it if its got 8 triangle shaped pucks the kit is the 98930hd.... good clutch im running one myself and love it ... strong pedal,,, smooth release.. and great grip no slip even on slicks.....i only no of one they make that stronger, and thats the 910 iron disk.... little bit radical for me
