Part number for Pilot Bushing??.. not Bearing.
We're doing my buddy's Ram HD install this weekend and we are going to use the bronze bushing this time.
I've searched... anyone have a part number??? Or is it the same as an old school SBC?
I'm pretty sure we can get one locally.. any tips?
Thanks
Steve
Thanks
Steve
It is pretty common for ls-1 owners to remove the tranny for clutch swap, and notice the stock pilot bearing has decided to come apart for what ever reason. For this reason I recomend the bronze bushings only. It requires very little lubrication. Less parts to fail. And lets not yet for get that gm used the bushings for many years previously. When the roller bearing comes apart it can cause all kinds of problems from a vibration to grinding of the gears to broken slave cyliders. If the bushing does get slightly damaged for what ever reason it will stil do its job where as the roller bearing can come apart. I don't believe that the little amount of friction that is reduced with the roller bearing is worth the added potental for failure.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
thanks for the info! not looking forward to doing this install again this weekend!!
seems to me the roller is to fragile. im sure many have no problem with it. but its been a pain to get the torque tube back in, and i think its been damaging the roller bearing on the way in. this bushing should take care of that problem!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
