RAM or MCLEOD????
Old 04-10-2002 | 04:16 AM
NASSTY's Avatar
Default Re: RAM or MCLEOD????
its all about the twin disk <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 04-10-2002 | 04:20 AM
Jason99T/A's Avatar
I can shift faster than you.
I was using the same prototype 11.5" disk Fireball was using and it flat out grabbed! I installed a 11.0" disk (the one coming with the kits now) and it drives better and doesn't seem to loose much in terms of holding power.
It did take me awhile to get used to driving with the setup. It really isn't bad at all after a few days of driving.
Old 04-10-2002 | 08:04 AM
Fireball's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by NASSTY:
<strong>its all about the twin disk <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Problem with the twin disk is that it breaks parts too easily. This iron clutch holds as much but doesn't have the initial bite the twin has so it seems a *little* easier on parts <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 04-10-2002 | 03:38 PM
chevyguy3's Avatar
thats why you build the rest of the drivetrain to handle it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> . i dont imagine the Ram setup would hold 900+ ftlbs. im not sure my street twin will either, but thats ok. ive got 2 spare street twin disks just begging to be padded with kevlar <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old 04-10-2002 | 04:22 PM
NASSTY's Avatar
well if the T56 can hold, the custom d/s, Spicer U joint and slpi yoke, 1350 rear end yoke, and moser 12 bolt with eaton posi, 4.11s, and 33 splines should. My guess is my posi will go and ill need a spool next. But it should hold for a few good runs. Im tryin to build THE top T56 setup. For n20 use too though, or else i would be grabbing some 4.56s or maybe even the dump truck gears fireball has.
