to bearing
Old 03-23-2006, 05:54 PM
purple98haz28's Avatar
Default to bearing
ok i just got my new slave from summit and it doesn't have a to bearing on it. there is a black disk (plastic) that sits in its place. my question is how do i install my throwout bearing????? i removed that platic disk and tried putting the to bearing in but the black tabs just will not fit over the bearing base plate. doe this make any sense cause it even has me confused. please help and fast. thanks all u techies
Old 03-23-2006, 07:59 PM
Ferocity02's Avatar
Could you snap some pics?
Old 03-23-2006, 09:09 PM
never mind i know my post didn't make any seense and i went back to the box and found a to bearing hidden in the packing that fit it. tranny is now in the car thanks tho
Old 03-23-2006, 10:28 PM
02WS6Bird's Avatar
is the TO bearing part of the Slave? For some reason i dont recall an extra part w/ my clutch install. I had the pilot bearing, flywheel, clutch plate, pressure plate and 01 Slave. thats all i recieved and that is all i took off the car. Would this cause it to be impossible to gain pressure or hard tor each full pedal pressure?
maybe im just expecting something to be wrong jsut trying to be sure and learn here so please help and bare w/ me
Old 03-24-2006, 06:26 AM
it is all one assembly but the to bearing is a different part. some companies sell alll put together some don't
Quick Reply: to bearing
