LS7 Clutch Info
LS7 Clutch Info
Here's some info on the LS7 clutch.
LS1 Clutch weight (2000 Camaro) (Flywheel, pressure plate and clutch disk) 50 lbs (after 14,000 miles)
LS6 Clutch weight (Flywheel, pressure plate and clutch disk) 50 lbs (after 25,000 miles)
LS7 Clutch weight (Flywheel, pressure plate and clutch disk) 58 lbs new
Here's a couple of comparison photos!
