Spec stage 3+ won't disengage
Just put the Mcleod adjustable master in. Fixed it, perfect! This thing is pretty cool. Definitely a much stronger looking piece than stock. Love that you don't have to use that POS U-bolt again. Im glad I didn't put another shim in.
I just had the stage 2+, SLP flywheel, and new slave cylinder installed and its doing the same thing, I have 60 miles on it and it still sucks. How much was your adjustable master cylinder? I can't decide whether to give it a few hundred miles or get the Mcleod.
LS1Tech Sponsor
We've never had a problem with the Spec setup,ussing the shim and 01+ hydrolics. Probly 30+ Spec installs and I don't waste my time bleeding the hydrolics unless we do the drill out mod.Then I bench bleed it for 2 minute's.
The dragging clutch sounds like it could be the aluminum flywheel or a PP bolt backing out. Another cause could be too long of a driveshaft which binds the tranny clutch assembly.That is a very common problem that is rarely talked about.
