Need Help
Old Apr 1, 2006 | 09:41 PM
Joe12345's Avatar
Default Need Help
I Have a 2001 Trans am with a centerforce Duel Friction clutch. I am having problems with my slave cly. I am on my second on waitng to fing out what is wrong before I go to my third. Is the clutch to strong? Is the slave over extending? I had the flywheel resurfaced when i put the clutch in. Has any body else had these problems? Can anybody help?
Old Apr 2, 2006 | 08:33 PM
The PAT WS6's Avatar
what flywheel are u using, i heard somewehere that u dont resurface ur stock flywheels and that they cause the slave cylinder to **** out, not sure tho..
Old Apr 3, 2006 | 07:28 PM
Mike44138's Avatar
How exactly are you slaves failing? Are they wearing out from the inside, over extending and blowing the seals? Any visible wear marks on the bad slaves?
Old Apr 4, 2006 | 07:37 PM
Joe12345's Avatar
Not really sure how they are failing show no sign of wear.
