What is the Blind puller remover part number from Autozone?
Old 04-14-2006 | 10:32 AM
SmaknaSS's Avatar
Default What is the Blind puller remover part number from Autozone?
Like the title say's. I wanna get a Blind pulley remover to pull the pilot bearing. Much thanks in advance.
Old 04-14-2006 | 06:55 PM
martinsw's Avatar
I just 'rented' one from autozone today - They just call it the blind hole puller. The tool box says OEM part 27128. Posts say this is supposed to work better than a clutch pilot bearing puller. Seems to fit fine, just not moving at all after a few dozen whacks.
Cleaned around the exterior edges, and put some screwdriver helper inside an on the exterior edges - waiting to try again in a little while. Maybe I'll ice the bearing for a while if this don't work. After icing, it pulled out fine.
By the way, I am also using a clutch pilot bushing from autozone - they called it a motormite # 14650, package also says it is a Dorman 691-014. I'm going bronze pilot bushing vice roller bearing....
Old 04-14-2006 | 08:51 PM
SmaknaSS's Avatar
Thanks for the reply.
Old 04-14-2006 | 09:23 PM
purple98haz28's Avatar
it worked like a charm for me. good luck
