LT1-LT4 clutch disc difference???
Old Apr 16, 2002 | 06:37 PM
timelord's Avatar
Default LT1-LT4 clutch disc difference???
Is there one??
Old Apr 17, 2002 | 02:54 AM
Damian's Avatar
LSX Mechanic
Default Re: LT1-LT4 clutch disc difference???
Yep. The LT1/LT4 clutch diff. is pretty much the same as the LS1/LS6 clutch difference. Slighly better disk and a strong clamping pressure plate.
I can't really tell what kind of car you have by the name and you don't have a sig. But i'd like to point the finger to a site with tons of excellent LT1 info. Go to www.camaroZ28.com and check out their "LT1 tech" section. They have EVERYTHING you could ever need to know about LT1's. Good luck....
Josh
Old Apr 17, 2002 | 03:36 AM
ChrisB's Avatar
Clutch disk is the same, pressure plate has an increased clamping force. The throwout bearing is different between the two. You can make a LT4 bearing work in a LT1, but it's not a great fit. The opposite is not true - you need an LT4 bearing with a ZF tranny.
Chris
Old Apr 17, 2002 | 08:08 AM
99MONGOOSE's Avatar
Isn't the LT4 a dual mass flywheel? Is the LT1 also a dual mass?
Old Apr 17, 2002 | 09:19 AM
timelord's Avatar
Sorry about lack of signature!!
You can try www.TimeLord3.com also.
Thanks for the info <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 17, 2002 | 11:53 AM
ChrisB's Avatar
Yep, stock the vette's are dual mass and f-bodies are single mass - but both can use a single mass flywheel.
Chris
Old Apr 17, 2002 | 04:02 PM
timelord's Avatar
I am mechanicly dumb,could you please elaborate on the difference.
I have seen posted that some people are using LT4 clutches on LT1 engines.
Are they using LT4 disc, disc & pressure plate or Disc pressure plate and flywheel.
Want to know which to swap to,can LT1 & LT4 components mix and combine???
Sorry for all the questions,,, <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
