clutch problems...time to replace?
Old Apr 15, 2006 | 04:24 PM
stang killa's Avatar
Default clutch problems...time to replace?
alright i went out the other night for some races, did some burnouts and power shifted all the races. when we were done with the last run and said bye i put my clutch in and it made a wierd grinding noise. it kinda sounded like something was spinning. is it time for a new clutch or what should i look for?
also, i jus checked my fluid and it is like maybe a 1/2 inch lower then the step mark. would that be enough to make these problems i am seeing? and should i be concerned that the fluid is black???
Old Apr 15, 2006 | 08:03 PM
anyone
Old Apr 15, 2006 | 10:46 PM
Shamson5.7's Avatar
Mine is making that exact same sound as you describe...Im putting a new LS7 in it, not because I want to.
Old Apr 15, 2006 | 10:53 PM
thats what im plannin on...
Old Apr 15, 2006 | 11:00 PM
just1news6's Avatar
DUDE mine is doing it too mines kind of like a squeaking noise when it engages or is under wot load it also soudns liek something might be clanking around in there
Old Apr 17, 2006 | 01:34 AM
Old Apr 18, 2006 | 03:06 PM
any body please?
Old Apr 18, 2006 | 05:41 PM
Camaro_Guy's Avatar
My clutch is grinding like of like that, it feels like there is something loose and spinning when the clutch pedal is down. I took it into a few shops and they told me it is a bad pilot bearing.
Old Apr 19, 2006 | 09:22 AM
just1news6's Avatar
i was told it might be a spring wiggled loose either way under load it bitches a lot
