Hydraulic Slave Cylinder & Release Bearing
I just bought a new centerforce dual friction clutch. On the box it says that the slave cylinder and release bearing need to be replaced but it doesn't say what kind I need to get. Does anyone know what I should get?
You should install a 2001+ slave cylinder, it is an upgraded version over the previous years. Sponsors will carry this item. Look at Byunspeed, they should have it. You should also get a new throwout bearing with the slave cylinder if it doesn't already come with one.
