How To Shift Diagram
i have performed only a few miss shifts and that was when i started to drive a stick a few years ago. a buddy of mine got a manual tranny a few months ago and all i have to say is hes botchy. he holds the shifter like hes holding a walking stick, w/ his thumb and pointer around the fattest part of the ****. throuout all his shifts, heres a miss, theres a miss, sweet, you grinded third.
he also likes to take off in second and wonders what the hell that vibrating is. im like you need to take off in 1st, and not shift at 1500...i donno, to me its just commoncents. i probably left hand shift from the passenger seat better than he can normally
1-2: with hand on right center of shifter ****, pull the shifter towards you and straight down
2-3: with hand on the left rear of shifter ****, put elbow at side and push at a diagonal towards the right
3-4: hand backwards on left center of shifter ****, pull straight down
4-5: see 2-3
5-6: push the shifter away from you and straight down; see 3-4
/thread
My friend still has the vid of him mis-shifting his s2000 at sears point where he ended up at over 11k on his programmer. Excellent driver in every respect, but he shifted like normal people, not adjusting his hand placement in accordance to what gear he was going to. After that extreme over-rev, he started shifting like I do and hasn't had a problem since.
Heh, last thing you want to do is shift if you're tight in a turn, or you'll upset the car's balance.
