Clutch stuck engaged.. hydraulic prob. plz help.
I'm in the process of installing and bleeding my hydraulic system. I've got an 01 transmission, McLeoud master.. I bench bled it, it got rock hard, no air.. I plugged it into the transmission, pumped the pedal, cracked the bleeder, got a good spurt, closed it up, continued until it came out clear. I pushed the clutch pedal, the clutch engaged and disengaged fine. Then I let it up, and it wont go down again. If the bleeder is cracked, it will go down fine, but if its closed, it wont budge. I dunno if maybe the quick disconnect wont stay all the way in or something. it pops in, then backs out about 1/16" and is locked there. It feels like it does when the quick disconnect isnt even attached.
anyone have any idea what's wrong?
olly
olly
