NEW Spec 3+
A lot of the problem was old c/pp being sold as the newer versions from independant shops. Some people are just not ever going to buy a spec because of all the bad post there has been in the past. If you search enough you will find out that there is something bad said about every clutch out there.....even the new textralia
well I have had mine in for almost 300 miles, so it is kind of hard to tell because I haven't got on it. The clutch engagement is great and no chatter anymore.
Very streetable in my mind.
anyone know how many miles on average does the 3+ suppose to last? does it have anything to do with the 4 or 6 puck on the disc vs a full circle disk (like stock)? >>>> less surface area more wear???
FYI on clutch ratings from SPEC's website
Stage 3 - 580ft/lb
Stage 3+ - 850ft/lb
Stage 4 - 700ft/lb
Stage 5 - 1200ft/lb
Does anyone know the PP clamp rates on any of the clutches or how much their flywheels weigh? I cant find that information anywhere, I have the aluminum flywheel with my 3+ and i love it but am curious what it weighs.
