need two plugs! (where to find them?)
Old Apr 27, 2006 | 03:54 PM
josh18_2k's Avatar
Default need two plugs! (where to find them?)
soooo i'm using an auto harness with a t-56 and i'm missing the reverse light plug and the revers lockout plug (the two male 2 prong plugs that are on a M6 harness). does anyone know where i can get these? i just need the pigtails so i can run my own wiring for lights and lockout, but no one seems to sell them in stores and getting someone to chop up a M6 harness prolly wont be easy.
Old Apr 27, 2006 | 06:17 PM
8a8mfh's Avatar
I just got mine from a junkyard. The reverse light wire plug is the same on almost all rwd manual trans GM vehicles since the early 80's. Even some other brands use the same plug.
As for the reverse lockout solenoid I somehow found one under the hood of a '95-'97 S10 pickup on the ABS unit.
Old May 3, 2006 | 06:52 PM
josh18_2k's Avatar
anybody know of like an ac delco part number for either of these? no luck so far finding a harness that i can cut into
Old May 3, 2006 | 09:30 PM
8a8mfh's Avatar
Go to the dealer, parts department.
Old May 5, 2006 | 02:02 PM
josh18_2k's Avatar
dealers dont sell them. tried that. they'll only sell the whole harness
Old May 5, 2006 | 05:17 PM
8a8mfh's Avatar
You need to try another dealer maybe. I asked for the clutch pedal switch plug and the guy brought a diagram of all the plugs at the pedals and on the trans. I got the pedal plug but never used it. Be persistant this guy was a bit of a dick when I was asking for parts for a 2002 camaro and he said they're not available. He changed his tune real quick when I started reading correct eight digit GM part numbers off the top of my head.
Old May 8, 2006 | 06:08 PM
josh18_2k's Avatar
do dealers sell the pigtails off an engine harness? i wouldnt think that they do.
so if anyone out there has these two pigtails available, please email me!
josh18_2k@hotmail.com
im gonna post in the wanted section too.
Old May 8, 2006 | 07:24 PM
8a8mfh's Avatar
I can get them for you. Although I don't see the problem of buying new or used, I've seen the diagram, like I said, and ordered the ones I could not find anywhere else.
Old May 9, 2006 | 08:08 AM
onebad82z's Avatar
Try
www.tpiparts.net
These guys are great to deal with.That is where I got the pigtails for my ongoing T56 swap.
Old May 22, 2006 | 07:47 PM
BigJoeBob1's Avatar
Junk yard or GM dealer
