Cant get in gear ... clutch or synchro's?
Old 05-02-2002 | 06:47 PM
WICKED SS's Avatar
Default Cant get in gear ... clutch or synchro's?
After this last weekend of a running on the freeway with this apu supra I cant get into gear for ****!
I barly made it home Saturday night and now its just sitting in front of the house, only gear I can put it in is reverse. It makes a loud grinding noise and all other gears it just wont go in no matter how hard I try <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
the clutch pedal is very close to the floor now?
So what could it be the clutch or maybe the synchros?
Old 05-02-2002 | 06:56 PM
WS6underPRESSURE's Avatar
Default Re: Cant get in gear ... clutch or synchro's?
Sounds like the clutch is not disengaging, try bleeding the slave cylinder, if that doesn't work, you may need a new master clutch cylinder, and maybe a new slave cylinder, but the synchros on the tranny should be ok, it sounds like the problem is in the clutch hydraulics.
Good luck. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ May 02, 2002, 05:59 PM: Message edited by: WS6underPRESSURE ]</small>
Old 05-02-2002 | 08:35 PM
blazinredls1's Avatar
most doubtfull its diffently your hydralics. You still have the stock clutch dont u? Get a new clutch with hydralics, look into the GP on ram i think there still having it. Also i dont see a aftermarket shifter, ditch the hurst with the short stick and go with an aftermarket, theres an slp one for sale in the classifieds..
Old 05-02-2002 | 08:42 PM
WICKED SS's Avatar
Thanks guys I was thinking it was the clutch too but someone told me that I would still be able to get in gear which I cant? I am most likly going to go with the Mcleod twin disk since I might be straying a 150 wet shot soon, dont want to keep changing clutchs all the time. I have the Lou short stick but I want the Pro 5.0 so I can still use my short stick.
Old 05-03-2002 | 12:20 AM
Im pretty sure the short stick on your hurst wont fit the 5.0 shifter. I remember seeing they have differnt handles.
Old 05-03-2002 | 02:48 PM
WICKED SS's Avatar
No not the hurst stick
I am going to use the Lou short stick that I bought not to long ago. The hurst shifter is just garbage!
<small>[ May 03, 2002, 01:55 PM: Message edited by: WICKED SS ]</small>
