Speedometer way off! Why?
Old May 20, 2006 | 05:30 PM
93z28camaro's Avatar
Default Speedometer way off! Why?
So I got the car back and it sounds good with the new pacesetter L/T and the big cam. Now however the speedometer is off by a lot. I had a chip burned but its a 93 so I didn't think that the chip would effect it. It says I am going 110 at 55 and baries it in third past 150 if your at wot. So any guesses. If the cable is burnt through it wouldn't work at all right?
Old May 20, 2006 | 05:31 PM
The car is a 6-speed if that makes a difference.
Old May 20, 2006 | 06:11 PM
BackinBlack02SS's Avatar
What kind of tires, gears, etc do you have?
Old May 20, 2006 | 09:29 PM
3.42 with 17 by 9.5 but before everything it was off but by like 5mph
Old May 20, 2006 | 09:50 PM
WHat size tires? What gears were stock?
Old May 20, 2006 | 11:17 PM
theantirotor's Avatar
i think he is saying his tires and gears have not changed since it was working normally...
Old May 21, 2006 | 01:02 AM
cantdrv65's Avatar
Post
The computer has an improper calibration for the speedo....have the tuner fix it.
Old May 21, 2006 | 12:03 PM
jessmansweet's Avatar
Sounds like an auto instead of manual speedo calibration. Auto=40 pulses per rev manual=17 pulses per rev.
