Hit 3rd and something gave out - help!
I roll to a stop and clutch hydraulics feel good, no fluid leaking from underneath or nothing. I pump the clutch and put it into gear and go to take off and as the clutch engages i just hear it clunk and rattle and i start to roll forward a bit but then let it out and stop. After that it was giving me a hard time getting it into gear and after letting it sit for a bit it let me and i was able to limp home but i had to be really easy on it, any acceleration would just let the revs jump and make a nasty sound.
I was thinkin maybe the throwout bearing went, it was giving me a hard time getting into gear and back out of gear with the clutch pushed in but it would then all of a sudden just slide in if i turned the car off and back on or just gave it a bit of time.
So im putting in a Spec 3+ w/ aluminum flywheel
Anyone know the weight of the spec aluminum? stock flywheel is 28lbs right?
