Tranny banging
You can acually hear it smacking off of something.
I replaced the tranny mount, and it lessened the problem, but now it is doing it REALLY bad, i swear, if i hit a piece of sand, it will do it.
Im pretty sure it is the tranny, but im not 100% sure, if im just crusin at a steady speed, and give it gas real fast, you can also hear the bang.
Maby something came loose that we did, i dont know (i will try and check tommorow) but does anyone know what my problem could be, and how to fix it? I am kinda afaraid to drive my car now, i dont want to mess anything up.
Thanks!! and I hope i can get some help
thanks, ill look under today, how did you fix the problem??
Thanks
edit* I was thinking, but if it was the cat, why would installing the tranny mount fix the problem for a few days???
lol,thanks
Thanks, i will also check that out.
I feel like i wasted $80 on a tranny mount now
I looked at the torque arm, and i really didnt see anything wrong with it... but i can tell you right now, when i hit bumps, or hit the gas really fast, i can hear the noise right next to me where the shifter is.
What exactly do i need to look at on the torque arm??? I tried wiggiling it around, and it didnt budge, and all of the rubber pieces looked fine..
Thanks
Thanks
lol,thanks
i didnt baby it, i drove normally.
I wasnt sure if the tranny mount would fix the problem, so i drove normal to see if it did, and the first day it only made the clunking sound 2 times, (this was last weekend) now it is making the noise just about every 10 seconds. *when i hit the gas really fast while cruzin, or hit a bump*
When i downshift i can hear it now, and it never did that before the tranny mount.
I was driving and i accidently put it in the wrong gear (well acually i shifted too early when i was slowing down) and the car started bucking and i could hear the noise... every time i heard it, i saw the shifter bouncing up and down too.. if im not mistaking it made the noise when the shifter was going down from the bounce.
Does this sound like anything??
*edited
Double check the torque arm mount, check to make sure the trans and tunnel cross members are tightened down... if what you're hearing is in fact the trans hitting something those are the things that would cause it.
Im just about positive it is the transmission though, unless somehow the engine mounts are making the tranny bounce around.
Thanks though.
The crossmember is tight, and the tranny is tight on the mount. They were torqued to specs. (well, to ls1 specs anyways)
I tried moving the torque arm around, but it didnt budge,,, i did only have half of the car on jackstands, so maby that was why, or im messing with the wrong thing
I heard taking the torque arm off of the tranny is a bitch, or something to the effect.. any tips?
thanks
edit*
Is there any links that will give me an approx. price im looking at here, thanks.
It was the exhaust smacking the crosmember behind the tranny crossmember, i just jammed a piece of wood under the exhaust and the xmember, and the sound went away.
Im going to make a new thread in exhaust, and find out why it is hitting.
Thanks for all of the help though
