winding when in gear
Old Jun 14, 2006 | 10:05 AM
JD_Z28's Avatar
Default winding when in gear
Just last week my tranny started to make a winding sound when in gear. The throw out bearing is brand new so it shouldn't be that. It seems like the harder im on the gas the louder it gets, and it does it in all gears. The noise sounds like its comming from around the shifter area. I checked the fluid and it fine now, but I was running a little low.
Old Jun 14, 2006 | 12:57 PM
JD_Z28's Avatar
Does anyone have any idea what it might be?
Old Jun 14, 2006 | 01:02 PM
Dal1as's Avatar
My clutch whined a bit after it was installed.(Replaced everything) Not sure if it's normal but it's pretty much gone away now and everything still works. I dunno.
Old Jun 14, 2006 | 01:52 PM
JD_Z28's Avatar
After I installed my new clutch and flywheel I didn't have these issues till about 600 miles after. The noise sounds almost like there is some grinding going on. When I tap the gas there is a quick grinding noise that accurs for a second.
Old Jun 14, 2006 | 04:09 PM
Dal1as's Avatar
Hmmm, I get no grinding noises. I'd get someone to look at it.
Old Jun 14, 2006 | 07:49 PM
blkbird's Avatar
I was getting a loud whinning but it was coming from my rear end. My bearing in my pinion were toast. I just got it fixed today and they put brand hew carrier and pinion bearings. No more whinning....
Old Jun 15, 2006 | 10:32 AM
GuitsBoy's Avatar
I get a little bit of gear noise from my tranny. Seems to be louder when i run synthetics. Regular ATF seemed to quiet things down.
