Won't move
Old Jul 3, 2006 | 03:05 PM
brokez's Avatar
Default Won't move
Ok car has a spec 3,ram adjustable master and the updated slave.I put the car in reverse to get out of the garage and the car would just rev and not move.So then I let the clutch out all the way with the car in reverse and it still wouldn't move and it didn't stall out.It was like the car was in neutral.So what is wrong?
Old Jul 5, 2006 | 02:38 PM
Mike44138's Avatar
Is it only in reverse? If so sounds like internal problems... if not it could be a pressure plate stuck disengaged.
Old Jul 5, 2006 | 05:52 PM
Phlip00WS6's Avatar
If its any gear then its hydraulics, if just reverse then its internal. Im guessing that it didnt do it before so its most likely your M/C isnt adjusted correctly or you didnt put the shim in behind the slave.
Old Jul 6, 2006 | 05:00 PM
brokez's Avatar
No it's in all gears not just reverse.And when it started I could be on the highway and it felt like I was spinning the tires anytime I hit the gas.Car shifts the same it just won't move.
Old Jul 13, 2006 | 05:34 PM
brokez's Avatar
Turns out the spec 3 is toast after only 4 thousand miles.Anybody had any luck with warranty on these things?It was installed by a professional and not even sprayed yet and it still burnt to hell
