where to buy ls7 clutch?
This is what you will need:
TO bearing would be a good idea
Blind hole puller (to remove bearing), rent it from autozone. $150 deposit though. But its worth it.
01-02 slave cylinder
Clutch disk, presure plate, flywheel www.fredbeansparts.com ( Part number: ls7clutchkit $487 +50 shipping)
Most likely a new master, get it if you have the extra 100. If not wait and see.
I think thats about all youll need..
Well, Go to T56rebuilds.com they have fantastic customer service, give them a call, and they will help you out, and explain everything you need. You are running the 98 hydros, while you are down there, you need to upgrade, go here, its where I got my Updated GM hydros http://www.ls1speed.com/catagory.cfm...y=Transmission scroll down and in the "Spec" clutch section, order P# GM4101 UPDATED GM HYDRAULICS you are garanteed to get the updated parts. With that said, I couldnt be more happy with my set up, and I am at just over 5k miles on everything. Good luck.
