Tranny uh oh
Tranny uh oh
I was driving in 6th gear at about 50mph. Just cruising. All of a sudden I heard a clunk and a jolt throughout the car. The car began to not want to drive smoothly or really want to move. So i decellarated and waited a second. I tried putting it into gear. And it didn't want to go into gear at all. I don't think it is the clucth. Pressure on the pedal is normal. And Car will still roll when clutch is pushed in(it didn't at first when I pulled over).. Here are the tranny specs.
Blue printed T56, Upgraded synchros, Stainless 1-2/ 3-4 shift forks
McLeod twin disk clutch with cintered steel flywheel.
The guy that owned the car before me had it built. The new setup only has a couple thousand miles on it. EVERYTHING is brand new. Broken in.. Haven't been able to even abuse it the slightest. I have fuel cutout because twin 340s aren't enough pump. I was putting an eliminator in this week w/ new rails, tank, and line. Now I have to deal with this ****...Any info??
The guy before me had it built. So I'm unsure.. Supposably built w/ Viper specs to handle 1000+hp.. But that's irrelevant because I have fuel cutout issues w/ the current fuel pump so I couldn't even give it the power... Could have been a shitty tranny build. We will see tomorrow!
Originally Posted by Ls1Joe
Bad thing is even with Viper input and output they will not live past 700. Hope it is not as bad as it seams.
Thanks,
Amber
Thanks,
Amber
