LS-6 Clutch part #'s
Old May 28, 2002 | 11:40 PM
StangSlayerSS's Avatar
Default LS-6 Clutch part #'s
I need a clutch real bad and decided on the ls 6 but my dealer dosent know squat about it. so i need the part numbers for the clutch,flywheel, pressure plate assembly and the adjustable slave and also the master cylinder.
Old May 29, 2002 | 12:27 AM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: LS-6 Clutch part #'s
12570806 – 2002 LS6 Flywheel w/ pressure plate and disc
12565145 - 2001 FBody Slave Cylinder
12570277 - '01 -'02 Fbody Master Cylinder
Mcleod adjustable master cylinder - Mcleod adjustable master cylinder
Old May 29, 2002 | 07:33 AM
BIGBOS's Avatar
If you are making any sort of power I would stay away from those "z06" clutches... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 30, 2002 | 06:40 PM
what about a spec stage 2
