Noobie: Clutch Change Question?
I am about to change the clutch of my 1998 z for the first time.. ( Installing a Z06 clutch , pressure plate, flywheel and throwout bearing.. etc..
Do I need to buy both the master and slave cylnders - ( UPDATED 2001-up)
to complete the swap.
Or do I just buy the slave cylinder..
WHAT OTHERS THINGS MIGHT I NEED.
Help aprecitated..
Help aprecitated..
You dont have to buy either to complete the swap, but you might as well put a new slave in. If it dies its gonnn **** you off because you'll have to drop the tranny again to get to it.
If you have the money, go ahead and replace the master just so its new and it wont be a worry to you later on down the road.
Make sure to have an extra jack for the transmission and plenty of jackstands. A ratchet with a swivel head will make the bolts on the top of the tranny much easier to get.
heres what i bought for mine.
ls7 clutch/ pressure plate
ls2 flywheel
01+ master cylinder
01+ slave cylinder/ to bearing (comes as set)
pilot bearing
arp flywheel bolts
arp pressure plate bolts
buy some dot 3 or 4 fluid also and some red locktite for those bolts.
ls2 flywheel
01+ master cylinder
pilot bearing
arp flywheel bolts
I would replace both of them, and it wont hurt to replace the pilot bearing, I even replaced the pilot bushing when I replaced the slave.
Personally, I wouldnt use locktite, you never know whats gonna happen and you'll have to drop the tranny again. Its just personal preference though.
Originally Posted by silverthriller
the slave is about $60 but not necessary and neither is a master.
Don't listen to this info. A good slave can be up to $130 & IS needed on a 98' model car getting a new clutch installed. If this is not replaced it can cause you problems later.
As for the master, some people go ahead & swap them out some do not. I still have mine & its working fine for now.
Originally Posted by BIG_MIKE2005
WRONG
Okay.. Slave and Master!
Looked them up on Gmpartsdirect.com , their expensive..
over $ 200 for both master and slave..
I went to Oreily's and had the master $76 some odd bucks
and the slave $64 bucks, also I can get 30% discount..
Will these also work?/
Help aprecitated..
Help aprecitated..
Definitely do the pilot bearing.
get the slave from summit, $110.
