Question on how to bleed the LS7
When I have the car shut off I can go through the gears without much difficulty but when i start the car up I can't find any of the gears and I can only get it in 1st and 4th and when i try to roll alittle in 1st in the garage it engages right off the floor like people said. I just don't know what to do I probably need to bleed it but could someone tell me how to correctly because I am not 100% sure how. Should I take it out for a ride even though right now I can only get it in 1st gear in the garage I have not tried to drive it down the road yet, I just don't know where to go from here. Thanks guys for you help and instructions on how to take care of this problem.
-Steve
Disconnect the line that goes in the slave from the master cyl
Push the center of the line so fluid comes out with a small screw driver.
have someone slowly push and hold the clutch to the floor, remove your screw driver, release the clutch.
check the master cycl, fill if necessary.
Repeat 2-3 times.
Connect the line to the slave.
Then, pump the clutch 10-15 times hold clutch to the floor and crack the bleeder, close the bleeder.
repeat till you get a good pedal.(CHECK YOUR master cyl so it does not go dry)
Using the mity vac did not work for me.
Took about 20-30 minutes to get good pedal on my old car using this method.
https://ls1tech.com/forums/showthrea...light=Mity+Vac
