What fluid to use in M6
Old Jun 3, 2002 | 06:51 AM
01 NBM DEMON's Avatar
Default What fluid to use in M6
I am planning on changing my tranny fuild this week and was wondering what out there is good to use?
Old Jun 3, 2002 | 09:43 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: What fluid to use in M6
I've just been using regular Auto Tranny Fluid (ATF). Redline makes some ATF and manual tranny fluids, either will work fine.
Tony
Old Jun 3, 2002 | 09:44 AM
rom3's Avatar
I just did this a few weeks ago. Recommended fluid is Dexron III automatic trans fluid (there's even a sticker on the trans itself saying this). Some have had issues with synthetic fluid (possibly because it is too slippery to let the synchros do their job of matching gear speeds). I went with Valvoline Dexron III (regular non-synthetic). Not sure if it was just because I changed it (car had ~14,0000 miles) or if the Valvoline works better than the factory fill, but I noticed smoother shifting especially the 1-2 and the going into 1st gear coming to a stop sign or whatever. I put in a little under 4 qts.
