damn it to hell top bolt t56
good luck!! can get them out in less than an hour laying on our backs. Took the first one out without removing the bellhousing and it sucked. Have now done about 10-15 by taking them off the bellhousing first. very easy
I just pulled my A4 the other night (that was a royal P.I.T.A.
. My plan was going to be to bolt on the bellhousing first, then bolt the tranny to that ... hopefully that will work well?
. I even broke the tip off a screwdriver trying to get it in between the two to seperate them (but that was before I realized I actually FORGOT ONE LAST BOLT!!!
)... before I put the new tranny in, I definitely want to put some never-seize on those dowel pins
. also, ill second that its much easier to pull the tranny w/out the bellhousing, and pull the bellhousing after the tranny is out...
the more you do it, the better youll get. i can do it by myself start to finish in about an hour and a half now...******* clutch hydraulics...
