Drill mod/Bleeding method
Old Aug 1, 2006 | 06:21 PM
brantsz's Avatar
Default Drill mod/Bleeding method
Rather than bench bleeding the line and then bleeding it again after you install it on the car is there any reason you couldn’t open the bleeder once the line is attached to the tranny and use a VAC? Am I missing something here?
Thanks for any info
Old Aug 1, 2006 | 08:57 PM
wrencher's Avatar
wrencher
I would still bench bleed it just to get the debris from the drilling. Just in case the flushing didnt get it all after it was drilled out.
It is pretty simple to bench bleed it. Then vacuum it out in car.
By Brett Foote | 2026-06-04 05:00:17
