downshift problem 94 T56
im going to replace the clutch soon as i know the idle grinding is from the flywheel and pressure plate. or the disc springs giving out. the previous owner complained of the same thing after he had the centerforce put in. do i need a shim of some sort?
anyone know why its hard to get into gear downshifting?
If you know the clutch is bad/ you cannot expect the reciever of that operation, the trans, to work right.Post after you have corrected the clutch ills.
