Reverse locked out-Searched
Old Aug 17, 2006 | 01:45 PM
Black01M6SS's Avatar
Old Aug 18, 2006 | 11:03 PM
wrencher's Avatar
wrencher
Well then your problem likely is either the PCM wont ground the solenoid or cannot ground it.
Need to figure out which.
Anything out of the car , modded, cluster BCM A/C stripped for racing etc?
Has a working speedo & cluster? Was there ever wiring problems on the car?
Have access to the data steam from the PCM?
Old Aug 19, 2006 | 12:21 AM
None of the wiring in the car has ever been messed with besides the stereo. AC, speedo and cluster have never been messed with. There has never been any wiring problems. I don't have access to the data stream from the PCM.
This started after a cam install. It was working the day I started. Took me 2 days to swap the cam and it wouldn't work after. The only thing unplugged that I know of is the driver side o2 sensor. I need an extension for it.
Old Aug 19, 2006 | 12:38 AM
qwikz28's Avatar
mine happened after a clutch install.
Old Aug 20, 2006 | 02:37 AM
Back to the top for the Sunday group :-(
Old Aug 20, 2006 | 07:54 AM
Farmer2's Avatar
Did you do any tuning for the cam after the install? If you know someone with HpTuners they can trigger the reverse solinoid and check on a true command from the PCM. It does sound like it is originating from the PCM now. Is it possable you disconnected or broke the ground going to the pcm? Maybe check that too.
Try pin 40 and 1 on connector C2 red, and see if they are a direct short to ground when ohming them out at the connector. Maybe the pcm is working properly but the grounding is bad. And again make sure the connection at the pcm to connector C2 is solid and all pins are making good. I would say if the grounding of these 2 pins are ok then it has to be the pcm. Do you know someone that has a pcm from a M6 and you guys could swap and try, if the above test proves direct short to ground?
Dave
Old Aug 20, 2006 | 03:31 PM
Dave
I didn't do any tuning but the car runs great. Idle is so smooth its disapointing. I don't know of anyone with HpTuners. As far as me breaking a ground to the PCM. I highly doubt it but that was the next thing I was thinking I should check too. Everything except the reverse lock out works just fine. I don't know of anyone around with another m6 that I could swap PCM's with.
Thanks for the reply. I'll check and make sure the PCM has ground later and post up.
Old Aug 20, 2006 | 04:48 PM
Pin 1 and 40 were both good grounds, 0.1 ohm on both.
Old Aug 20, 2006 | 05:52 PM
Farmer2's Avatar
I would say the pcm is acting up then. Try maybe a junk yard one, if you can find one.
What year car is it again?
Old Aug 20, 2006 | 06:18 PM
2001... That sucks.
Old Aug 20, 2006 | 06:23 PM
qwikz28's Avatar
2001... That sucks.
interesting twist to my car story, my first gear lock out is now going as well. it takes a couple tries just to get it in first at times. do you have that problem at all?
Old Aug 20, 2006 | 07:13 PM
  #32
I only drove the car once since the reverse lock out messed up but I didn't notice anything wrong with getting into any gears. Just really hard to push it over so I could put it in reverse. 64k miles on the car, kinda makes me mad that its having computer problems. I still have a vortech supercharger kit to install. It would really be bad if the PCM messed up after I get it tunned.
Old Aug 20, 2006 | 07:36 PM
  #33
qwikz28's Avatar
doesnt first gear also have a lock-out? thats the only gear i'm having trouble with
Old Aug 20, 2006 | 08:39 PM
  #34
Don't think so. When are you having trouble getting into it?
Old Aug 20, 2006 | 09:12 PM
  #35
qwikz28's Avatar
off a traffic light. kinda like how you cant shift into 1st while going at a certain speed? i guess its locking it out when its not supposed to be. i usually just pump the clutch once or twice and it works again, if not, i just force it in there
definately pcm related man, everything trans related is falling apart after this clutch install
Old Aug 20, 2006 | 10:01 PM
  #36
Sounds to me like the clutch isn't fully disengaging. Might try bleeding it some more.
I don't think there is anything really stopping you from getting into any of the gears. Its harder to get it into lower gears at higher speeds because the syncros have to do more work when there is a large change in speed from one gear to the next. Lots of people have bent pushrods from shifting 1,2,1 at high rpms.
Old Aug 20, 2006 | 10:22 PM
  #37
qwikz28's Avatar
it only happens at a stop going into first gear. and it doesnt feel hard, it feels like something is in the way. the first gear thing is recent, the reverse lockout problem happened right after the clutch install (which i didnt do btw)
Old Aug 20, 2006 | 10:48 PM
  #38
ssman00's Avatar
this sounds like you need to bleed your clutch some more my car did the same thing hard to shift into first all other gears were fine ( after freshley rebuilt t56, spec clutch, gmpp slave cylinder) just bled it a few more times (it took alot of bleeding) and works perfect now
Old Aug 20, 2006 | 11:00 PM
  #39
Make a new topic about it and get some other opinions if you want. I'm no expert but I still think your clutch isn't fully releasing. It would be most noticeable from a stop trying to get it into first gear like you said. Once your moving it is possable to **** without a clutch. Up and down, you just have to rev match and don't force the shifter.
Old Aug 21, 2006 | 05:44 PM
  #40
qwikz28's Avatar
i'm more concerned about the reverse at this point. i was just assuming the two problems were related. i guess not
