Ls7 grabs anything i throw at it!!!!
Old Aug 14, 2006 | 08:25 AM
Phlip00WS6's Avatar
Originally Posted by boondiggys
will an ls7 pressure plate/ disc bolt onto a stock resurfaced ls1 flywheel??
Nope, youll need the vette LS2 flywheel
Old Aug 14, 2006 | 10:55 AM
Cyborg's Avatar
Originally Posted by Phlip00WS6
I talked to someone with heads/cam/spray with close to 700 rwhp on the ls7 clutch and it holds just fine on the street and at the strip on DR's.
Before somone goes out and buys a LS7 clutch expecting it to hold 700 RWHP at the track with DR's, you might want to think that decision through. The LS7 clutch is designed to handle ~445 RWHP, on the street only, on street tires. You really should not expect it to handle WAY more than that.
Old Aug 23, 2006 | 04:25 PM
Ranger's Avatar
King of the radial tires
I'll take it a step farther. I have an LS7 clutch on my C6Z and it is not track friendly at 450 rwhp. It will glaze on a 2900 rpm launch if you slip it 5'. It will glaze no matter how it's launched >3800.
On stock tires, it will take a 3100 launch with a very fast clutch release, so long as it gets no more throttle until the clutch pedal is all the way out. Same for a DR launch at 3500, but no higher.
So the LS7 is not track friendly. If you want to launch the car at 4K or more, start looking somewhere else.
I don't know a single C6Z06 owner that makes passes that likes this clutch. Quite a change from the view we had as stock C5Z owners talking about the LS6 clutch.
Ranger
Old Aug 24, 2006 | 03:58 PM
NemeSS's Avatar
Ranger
ranger,
so what clutch setup do u recommend for street tires and street use BUT
5K+ launch with dr's on the strip for about 525 rwhp
also using a 2 step, at the strip and a 150- 200 shot
Old Aug 24, 2006 | 04:09 PM
Ranger's Avatar
Originally Posted by NemeSS
ranger,
That requirement is beyond my personal experience other than to say that the LS7 clutch won't come close to handling it.
If the total max rwhp is 525, I'd take a look at the Cartek Level-7 clutch. Plenty of folks have used that one at your power level.
If instead you are writing 525 + 150-200 and you want to do a slip launch, then you have a requirement that will be hard to meet. I would engage owners with your specific requirement via a post to the Forced Induction board here and the CF.
Ranger
Old Aug 24, 2006 | 06:04 PM
Turo's Avatar
Originally Posted by 93camaro_zzz
T56rebuilds has got it for $600 shipped, and that includes the aluminum flywheel. I am ordering mine next week, along with an 02 slave.
WITH aluminum fw? Damn, tahts a pretty good price (those aluminum fw's can cost a pretty penny).
Old Aug 25, 2006 | 12:37 PM
NemeSS's Avatar
Ranger
yea, the 525 is on motor N/A +150/200 shot.
a/c delete fbody, tubular k member, full int.
i will look into more info, thanx
Old Aug 25, 2006 | 01:03 PM
Tobynine9's Avatar
It's not an aluminum FW. Go to their website. It's the stock LS2 flywheel.
I love my LS7 clutch. Simple bolt on installation although I opted for ARP fasteners instead of re-using the stock pieces.
