Ram clutch...use their flywheel or stocker
We have a car that we put a ram clutch in and used a new stock flywheel. Now the car is having trouble going into gear. The shop we got the clutch from says we need the ram flywheel because the clutch isn't fully disengaging with the stocker. Does this make sense? I don't really want to go through the expense and hassle if it's not the problem.
FMS installed mine with the stock flywheel resurfaced and put 2 small shims at each bolt on the pressure plate..........RAM PowerGrip with 300series disk.........FMS adjustable master too.
