just need to make sure
Old Sep 12, 2006 | 11:18 PM
89Formulaws6's Avatar
Default just need to make sure
i don't know 4th gen t-56's and my 94 needs a new one so can i use a 97 t-56 or will i run into probs?
thanks
i plan on useing a ls1 aluminum driveshaft as well
Old Sep 12, 2006 | 11:57 PM
DaGeneral's Avatar
You should be fine with the transmission. I believe your problem would be if you used an LS1 Tranny, which has a different bellhousing, among other things.
I am not sure about the driveshaft.
Old Sep 13, 2006 | 12:19 AM
driveshaft i've read is a common swap so i'm good to go
thanks for clearing things up
Old Sep 13, 2006 | 08:30 AM
calhoon's Avatar
You may want to be sure that '97 box has the iron 3/4 upgrade(at least) and use only an ATF fill if the blockers have not been changed to the carbon-particle lined parts.
Old Sep 13, 2006 | 12:26 PM
pshh like the guy i'm buying it from is gonna know that lol
its used and i'm actually getting it froma guy whos local but on here i can try and ask him lol
