Can a Z06 slave cylinder be used in F-bodies
Old 09-13-2006, 10:45 AM
2002SilverWS-6's Avatar
Default Can a Z06 slave cylinder be used in F-bodies
Will a z06 slave(89059282) work in my 02 F-body instead of using the upgraded slave(15046288) are these two interchangeable. What are the differences and if it won't work can you please tell me why?
Old 09-13-2006, 11:34 AM
DONAIMIAN's Avatar
Id imagine the slave body itself is the same, but the connections for the feed and bleed would be different.
Old 09-13-2006, 01:15 PM
kpforce1's Avatar
Old 09-13-2006, 01:39 PM
2000TransAmWS6's Avatar
like they said... you're going to have to stick with the f-body upgrade, i think that they are basically the same, but the z06 slave has much longer connections.
