spec stage 3 or 3+
either or, i had a spec3 and it was one of the many that pooped out...i'de go with the 4 or 5 because they don't have the springs in the center
you will burn that up in a few thousand miles if you try and modulate the clutch to be smooth the springs alow smooth engagment of the clutch I have a spec 3 and it is great if you need the extra holding power go 3+ I thing with your power level go 3+
I just had a SPEC 2+ go out in about 2k miles, and I've already got a Ram HD sitting here waiting to go in tomorrow. Screw that. I gotta call SPEC to see how they're gonna fix their junk but I doubt they'll do anything.
Turns out the clutch and pressure plate are great. It was the pilot bearing. The needle bearings had fallen out and were chewing my input shaft ever so slightly. Not enough to do anything other than groan a lot. Thankfully.
