Shifter problems
Old Sep 21, 2006 | 10:16 AM
wkniffin98ss's Avatar
Default Shifter problems
I just bought a pro 5.0 shifter and it has a lot of play in it, how do you adjust it?
Old Sep 21, 2006 | 11:31 AM
Nobody knows?
Old Sep 21, 2006 | 01:39 PM
calhoon's Avatar
There are no "play" adjustments on that shifter- If there's play something is worn, loose or poorly installed..
Old Sep 21, 2006 | 01:49 PM
How could installation effect it? What could I have done when installing to cause it to move back and forth? The movement is front to back not side to side if that helps.
