LS7 Clutch install help
Old Sep 25, 2006 | 03:06 PM
LSGunZ28's Avatar
Default LS7 Clutch install help
I am gonna install my LS2 aluminum flywheel with the new master cyl and LS7 clutch and pressure plate.
I need instructions on the whole thing. can anyone provide detailed instructions, preferrably with pics?
also If the aluminum LS2 flywheel wont work, Im gonna try the LS2 steel flywheel.
Any input would help.
Oh and also can anyone help me bleed the clutch correctly? (with instructions)
Old Sep 25, 2006 | 05:30 PM
LSGunZ28's Avatar
Also 2 more things, do I need a hydraulic pump to bleed the master? and how can I obtain one if so. Also my aluminum flywheel has minor surface scratches on the side that bolts up to the crank.
Old Sep 26, 2006 | 10:03 PM
LSGunZ28's Avatar
Help!!!!!!!!!!!!
Old Sep 27, 2006 | 05:01 PM
LSGunZ28's Avatar
OMG Hurry! Time is running out!
Old Sep 27, 2006 | 07:18 PM
1998z28ss's Avatar
Check out www.installuniversity.com and do the mcleod clutch walkthrough, thats what we used for my clutch install. I dont know how scratched your flywheel is but you want your friction surface to be as smooth and as nice as possible as that is 1/2 of your clutch engagement!
Old Sep 28, 2006 | 02:10 AM
LSGunZ28's Avatar
But it isnt on the friction surface, its on the surface that faces the block..
Old Sep 28, 2006 | 02:18 AM
rollinna65's Avatar
Then you're good.
Old Sep 28, 2006 | 10:44 PM
LSGunZ28's Avatar
Yeah, but its toward the middle, what about vibration increase?
Old Oct 2, 2006 | 03:26 PM
LSGunZ28's Avatar
wouldnt it?!
Old Oct 2, 2006 | 03:45 PM
BIG_MIKE2005's Avatar
not unless you got a damn crader in it. Just a surface scratch which I consider a scratch like what you would find on a CD, won't hurt anything as long as its not on the friction side.
The LS7 clutch is VERY simple to install. Just use the link provided above for the torque specs & general info. This clutch assembly bolts right up very easily. Just make sure your flywheel is lined up correctly & that your clutch alignment tool goes in & out freely after its all torqued down. ALWAYS DOUBLE CHECK IT.
Stab the tranny back in & bolt everything back up in same order you removed it. Make sure to tighten in a criss-cross pattern. You can either use a Mity Vac or the old school method to bleed it.
Old Oct 2, 2006 | 04:22 PM
LSGunZ28's Avatar
thanks a million for simplifying it.
Old Oct 2, 2006 | 04:31 PM
Not a problem man. I was askin every question I could think of before tackling my clutch swap. I know how it is wondering about stuff. But once you do it, you will understand how easy it really is.
Good luck & let us know how it goes. Also the pedal will engauge right off the floor at first.
Old Oct 2, 2006 | 10:54 PM
CaliboyTA's Avatar
you should also buy a haynes manual. I've use that book quite oftenly. CLutch install on our cars are fairly simple, but time consuming. just take your time and try not to get fustrated. As for scratches, I had nurmerous surface scratches on my pressure plate from the shipping that concerned me. I took back to the performance shop and they told me the scratches are not deep and will wear away. So far I've handn't had any problems with my clutch. As for bleeding the system. I've tried the old way, but with the use of the mityvac was alot easier and less messy. I recommend you using the mityvac for bleeding process.
Old Oct 3, 2006 | 12:46 AM
LSGunZ28's Avatar
Also if anyopne can answer me. Im gonna install my Lts tomorrow. I should be fine doing the clutch later if I dont weld the Y pipe to the headers, correct?
Old Oct 3, 2006 | 02:01 AM
CaliboyTA's Avatar
correct
Old Oct 3, 2006 | 08:01 AM
I would NEVER weld it there. You always want to be able to take out the tranny or clutch without having to cut a couple welds. Especially off the collectors.
Old Oct 3, 2006 | 09:19 AM
V6 Bird's Avatar
Tack welding it would be fine...But not completely. And if its built right you dont need to remove the y-pipe to get the trans out of the car.
Thats how I build my exhausts and for others.
Old Oct 3, 2006 | 04:20 PM
LSGunZ28's Avatar
I think there are more than surface scratches. I may have to put on the steel flywheel
DAMNIT!
Old Oct 3, 2006 | 10:11 PM
CaliboyTA's Avatar
take it to a tranny shop and let them inspect it. Thats what i did with the scratches on my pressure plate.
Old Oct 4, 2006 | 06:50 PM
LSGunZ28's Avatar
scratches are on flywheel, not pressure plate!
