replacing master
Old Oct 8, 2006 | 08:20 PM
blacksskid07's Avatar
Default replacing master
allright so it looks like i'm gona have to replace my master cause it's gone bad, is this what's causing the pedal to get a lil softer, shifting to be little more difficult, and the squeaking. I'll get it replaced but anyone have any idea how much this i gona cost?
Old Oct 10, 2006 | 07:48 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Replacement would probably be 150$ in Labor.
The part will be anywhere from 140-200 depending on manufacturer.
How old is your slave cylinder? It might be time to change both just so you aren't running into a hydraulic problem with the other in the next 3-10k miles.
