clutch slipping
Old Oct 9, 2006 | 04:31 PM
Midnight SS's Avatar
Default clutch slipping
I had a spec 3 installed about 30k ago along with the drill mod to master and a new slave cylinder. My clutch will start to slip when i first take off or shift gears but then catches. Master or clutch going bad.
Old Oct 10, 2006 | 07:20 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Could be:
1. Master
2. Slave
3. Clutch Disc is worn
4. Pressure Plate is worn
5. Transmission is slipping
But sounds like it just needs to be adjusted or gravity/bench bled.
Old Oct 10, 2006 | 03:54 PM
Mike44138's Avatar
See if it slips in 6th gear at low RPM and low speed full throttle. If it does then it's the pp, flywheel or clutch disc.
Old Oct 10, 2006 | 04:02 PM
Billy177's Avatar
also make sure the pressure plate bolts didnt loosten up
Old Oct 10, 2006 | 08:10 PM
I tried to bleed still slips. Pulling tranny tom night. What clutch should I go with 380 rwhp?
Old Oct 10, 2006 | 08:23 PM
C.J.'s Avatar
30k is quite along time if you race the car often, its probably just due for a replacement.
skifast87's Avatar
i might have missed somthing. i think i did. But did you get the flywheel machined at all. or did you get a new one
Old Oct 10, 2006 | 10:11 PM
The Red WS.6's Avatar
What C.J. said and dkifast87. Search around and you will see other peoples stuff crapping out on them waaayyyy sooner than that. Lots of factors to consider.
Old Oct 11, 2006 | 10:53 PM
When I installed the clutch the flywheel was new.
Old Oct 12, 2006 | 10:37 AM
skifast87's Avatar
hmmm well there goes what i was thinking. Alot of times from what i understand if you dont get the flywheel machined down. Or replace it the clutch will slip alot sooner. You stated however you got a new one so im out of ideas
Old Oct 12, 2006 | 04:25 PM
Clutch fried. Does anyone here run the LS7 setup and if so do you like.
Old Oct 14, 2006 | 09:49 PM
Oh yea, I got the spec 3+ and has worked great for me. I had to replace my stock clutch at 30k too. Which, at the time, I was pretty easy on the car. My car now has 550 to the wheels. However, I don't drag race at a track either. good luck.
Old Oct 14, 2006 | 10:32 PM
Wnts2Go10O's Avatar
i have a used spec 3x with 3k on it if u really need it running
Old Oct 15, 2006 | 08:52 PM
badpewter-z's Avatar
LS1TECH Sponsor
sounds like its on its way out, if you got 30k outta a spec why not get another?
