Aftermarket master/slave setup
Old Oct 10, 2006 | 10:56 PM
fbody83's Avatar
Default Aftermarket master/slave setup
I've heard rumors that the stock hydraulics for the clutch doesn't move the fluid fast enough when shifting quickly. There is a piece that can modified to allow faster flowing if you drill it out so I've heard...
Have any of you experienced problems while trying to shift quickly on LT1's or LS1's? I'm asking because I broke my master cylinder before I could even use it and couldn't see if this was ever an issue.
Are there any "heavy duty" aftermarket ones that are worth it or no? I'm currently running a T-56 from an LT1 in my 83 firebird.
*BTW, the search isn't working... keeps timing out.
Old Oct 11, 2006 | 11:51 AM
fbody83's Avatar
Originally Posted by Machine
The 'drill mod' is under installuniversity.com. I wouldn't recommend an aftermarket master. I have had nothing but problems and will likely be returning to stock soon.
thanks
Old Oct 12, 2006 | 04:25 AM
gun4hire's Avatar
I've just bought the McLeod master and hopefully will have it in by this weekend. What issues did you have Machine?
The drill mod removes the restriction from the master to slave in '98-'00 cars. I am not sure if the LT1 cars (I'm assuming that's where your current trans/master cyl is from) had the same issue.
Old Oct 12, 2006 | 08:38 AM
gun4hire's Avatar
Good luck - I hop you get a good one.
Me too! For $300 you'd think it would be damn near indestructible.
Old Oct 12, 2006 | 01:45 PM
gun5l1ng3r's Avatar
So is the best bet the stock replacement from GM?
And does it come with the braided SS line that goes to the master?
And how is it pre-bled from the factory? Doesn't that mean it has fluid in it?
Old Oct 12, 2006 | 01:51 PM
Hugger Z's Avatar
Yes the GM Master is the most reliable at this point. Yes it comes with the braided line. That is what you need to remove in order to do the drill mod as seen on installuniversity.com. Pre-bled just means there is fluid in the line. Once you do the drill mod (and clean it out) you can bench bleed it to make sure there is no air in there.
Old Oct 12, 2006 | 01:52 PM
Machine's Avatar
I think that this is the conclusion. There are modified stock masters such as RAM that some people like, but I haven't tried yet. Don't know about what it comes with - the parts diagram I saw looked like it came with the SS line.
Old Oct 22, 2006 | 11:20 PM
gun4hire's Avatar
I used the McLeod. I did the drill mod, bench bled it, then bled it several times once installed. I then adjusted the pedal travel and it works great. *knocks on wood* It solved my spongy clutch pedal problem.
