slave cylinder problems
By the way H/C/I full bolt on car
Thanks
I had the same problem and it ended up being that my trans had the wrong length input shaft. (Had an LT1 shaft.) Not a common problem, but a few people up here have run into it.
https://ls1tech.com/forums/showthrea...t+shaft+length
I could predictably blow up a slave cylinder with a hard shift from 1st to 2nd over 4k RPM before I fixed my problem. I also had a slave blow up on me within 5 miles of installing it. The sleeve that surrounds the input shaft would show witness marks from the input rubbing against it, and would usually completely crack from the base of the slave. You'll know your input shaft is too short if the splines on the shaft don't clear the slave cylinder. Calhoon's right, it's more likely that the slave is over traveling, but it's worth looking at.
Sounds to me like the slave is being over travelled still.
