Spec Stage5
Old Oct 17, 2006 | 09:43 PM
KONG's Avatar
Default Spec Stage5
jUST WONDERING WHAT THE LIFE EXPECTANCY OF A STAGE 5 SPEC USUALLY IS? IT CAME WITH THE CAR, AND IS A BIT OF OVERKILL SINCE THE CAR IS JUST A BOLT-ON CAR. WHAT CLUTCH WOULD YOU GUYS RECOMMEND AS AN ALL AROUND STREET/STRIP CLUTCH? TIRED OF THE NOISE AND ROUGH ENGAGEMENT. ANY ADVICE WOULD BE A GREAT HELP.
Old Oct 19, 2006 | 07:18 PM
JTSLP559's Avatar
if you want to get rid of it let me know! i need a spec 5!. but. you should check out RPS clutches. they hold pretty good. my budd puts them in supras all daylong. never had a problem!
Old Oct 19, 2006 | 07:42 PM
Jake@EPP's Avatar
An all around street/strip clutch that will take abuse and have room for upgrades is the spec 3+ , its a full face clutch that isnt a harsh on/off engagement like the 5.
Old Oct 20, 2006 | 03:50 PM
KONG's Avatar
Thanks guys, I appreciate the advice. I will probably make the switch to that clutch, spec 3+, but I will wait until the stage 5 is worn out. I dont think I would sell it out right because I would be concerned with the longevity of the clutch. It has quite a few miles on it, very hard miles. Thanks alot guys.
