Mcleoud or Textrilla?
Swapped in a McLeod MC and shifting is great about 19 out of 20 times. Now the clutch sticks to the floor occasionally. Its random, sometimes in stop and go traffic, sometimes when racing. (when I installed the clutch there was no info regarding the mcleod/textralia issue several months ago)
So WTF do I do? OEM MC/Slave with Textralia and no shifting above 4K. McLeod MC and Textralia sometimes the pedal doesnt return. The only option left is McLeod clutch. I cant keep throwing money at the clutch.
If anyone has advice, post it up. I'm at a dead end. Why is the Mcleod sticking sometimes? Its not even 500 miles on it yet.
I however DO NOT like my master cylinder. And i think i'll be putting my OEM back in.
if someone could tell me the stock bore size and stock pedal stroke, we could calculate the volume of fluid moved by a stock setup..
and then calculate out the allowable stroke of the McLeod unit....
(also, it would help me since im a non-stock app....
) i'll check those out, thanks
When I first put the clutch in... times in sig.
Is there any hope for that in the future?
